I have lowered my T3 caravelle van and the rear tyres are scrubbing out bad on the inside. I have adjusted the lower arms as far as they go but still no good. Does anyone have a solution?
you must have something bent
Not familiar with T3 suspension but if it is a traling arm IRS (Like a Superbeetle or a Commodore) it will do that. You will need to 'correct' the geometry with an eccentrics inner bushes or similar
Nothing is bent i assure you, the issue is can you get eccentric bushes for the T3
good questian as my bugger has the same problem but as bad as yours it sems i do a pair of rear wheels every 2 years
