G'day.
I've only had a theoretical exposure to forced induction, so I have questions to ask about blow through forced induction.
I've been toying with teh idea of doing a blow through turbo setup on my van, especially since getting the weber progressive manifold and carb
setup.
It seems like the D(F/G)(A/E)V carbs can be used for blow through induction with few mods.
For the distributor it's easier to use an advance/retard dissy or a mech advance only unit right?
Does the vac line for the brake booster need a belt driven vacuum pump?
I saw an alternator with combined vac pump on ebay. Guess that could be used if I could get a belt to it (Type4 motor. No belt related cooling
worries)
How is fuel pressure regulated? I guess it'd have to be ran at a few PSI above manifold pressure. how does that work?
I think that's it; Just something I'm playing with in my head.
why not do a suck through?
blow thros are a pig to jet and tune for a first timer and for no real benefit
budget ignition u cant beat a limited 009 - not locked!
and fuel u will need a boost sensitive regulator, return line and a pump that puts out more PSI than the boost u plan on running
Interesting.
I can do what I like in the playground of my mind.
Thought it'd be more complicated, and it's not as if I'd need lightning response times in a camper. Just an idea I have been toying with to help it
out in the upper rev/speed range more than anything else.
Is an IHI4 too small for a 2 litre on normal road use?
Newt
All good. Thanks for that.
yeah I can't see a benefit of blowthrough for my possible application anyway. Not like I need wicked fast response etc. I just want something to
help it out a little on the hills, and flat really.
My setup already has enough torque that it can be hard to get it moving without spinning the wheels, but it needs a bit more topend power.
edit: talk !=torque. Did I have a stroke or something?
Any info on getting these one way valves?
I thought the thread was long dead. Thanks for the great one way valve explanation. Thats absolutely brilliant.
