Where can I find a list of Oz engine and chassis numbers on the net? Because I know US and OZ models are a little different. Cheers
there not available any where
Whats yr chassis number and i may be able to help
Thanks vw54.
Engine: 303, 0361
309, 4594
Chassis: 195, 722, 033
641, 0917
the Chassis: 195, 722, 033 indicates a Type 1 Beetle then the 9 indicates made in Aussie and the 5 indicates 1965
Hi bruizer,
You could always get a "birth certificate" for your vw from the Volkswagen AutoMuseum in Germany. They'll provide you with a reasonable amount of
info including date of manafacture, orignial colours and destination port. They will also tell you if your engine number matches your chasis number.
It will however cost you 35 euros, or about $70.
The museum's link is:
http://automuseum.volkswagen.de/home.html
You have to go to the kontakt section and send them an email.
The following web page helps explain the process:
http://www.dropgates.com/resto/identitycert.html
