wiring ea82 to kombi
hippys4 - September 15th, 2009 at 06:35 PM
hey im needing some in put i have put a ea82 in our kombi goes great but i am losing power on hills i mean it dies wondering if i need 2 run extra
wire for all the thermo fans & f/pump insted of from the coil
i have a 3 core under neath & the orig subaru in the back
makes it run cool running big d/ craig under neath & 2 subaru fans on the back rad or even better has some one got a wiring dig cheers olly
& hippy d
mnsKmobi - September 16th, 2009 at 02:24 PM
Originally
posted by hippys4
& hippy d
I wouldn't run the fans off the coil as the power for it comes through the ignition switch. I assume you are doing it to have the fans powered only
when the ignition is on. In that case, run a relay off the coil to switch power from the battery to the fans.
I doubt that is the cause of the engine dying under load, but it is a fix you should make anyway.
