fitting temp gauge
baghall - May 2nd, 2010 at 09:32 AM
Hi guys,
Any advice on where to connect an oil temp sender unit on 1600 twinport. Am also installing an oil presure unit in the spot where the old pressure
sensor is.
barls - May 2nd, 2010 at 09:37 AM
im going to assume that the engine is in one piece and in the car, otherwise id suggest drilling and tapping the sender in, so your two options are
the sump plug version and the replacement dipstick version.
the first replaces the sump plug and just screws in where as the second just slides in as a dipstick replacement.
vdo make a good version of both. i have only used the dipstick one though.
baghall - May 2nd, 2010 at 09:49 AM
Originally
posted by barls
Sounds too easy thanks
1303Steve - May 2nd, 2010 at 08:17 PM
For the temp sender you can get your oil pressure relief valve plug drilled and tapped, its best to fit it into a metric nut and get a machinist bore
the hole in lathe.
Joel - May 2nd, 2010 at 09:03 PM
dipstick wins it every time, sumpplug isnt as accurate, will read lower than actual oil temp
68AutoBug - May 3rd, 2010 at 12:32 AM
Originally
posted by baghall
Hi guys,
sensor is.
You can buy a brass extension piece so You can also use the light in the dash too...
and the oil sender in the sump plug will give You some idea..
baybug - June 1st, 2010 at 12:35 PM
I see you can also get "t" peice extensions, would you be able to put the oil temp sender there????
Vanders - June 1st, 2010 at 04:57 PM
Originally
posted by 1303Steve
the hole in lathe.
CIP1 have one already made for you:
http://www2.cip1.com/ProductDetails.asp?ProductCode=C31-115-431-400
