Can anyone please tell me if the alternator that I have purchased with numbering K1 14V 23/51A could possibly be a 75 amp alternator as I believe it
is probably a 51 amp alternator.
Is there anyway if it is a 51 amp alt that it could be upgraded to 75 amp?
John
No not really. Unless to machine the housing of the alternator shorter to fit a wider stator and also upgrade the rectifier. Not worth the time or effort, that is if it can even be done.
thanks for that info but are you able to tell me at all if with that labelling it means 51 amps { as thats kind of how it looks to me , but I'm
definately no auto electrician,}, as I was reading somewhere that I would have to beef up my wiring for a 75 amp
thanks for your help - seems pretty hard to find out otherwise - have tried googling but seem to hit blanks on 75 amp alternaters
john
Pretty sure the 51A does mean 51 Amp's.... that's how it works for sure with Bosch generators (don't have a Bosch alternator nearby to check, and
you're right about googling it)
On the wiring... well whether a stock charging wire will be an issue with a 75A can't say for sure, but if it was my car, well that wire would be
getting upgraded... pretty simple job if the battery is still in the standard spot.
thanks very much for this info - I appreciate it
Same alternator as mine, and Im 100% certain mine is a 90Amp alternator. Put 1 and 1 together and its easy to see the A follows the AMP output. But
you've already figured that out
thanks everyone for your replies
john
yes they're all 51 Amps..except when they are 55 Amps....
That is the first 55 ampere alternator on a beetle I have seen..
PS: 55 is the size of many other OE alternators..
Lee, it may be true that its the first 55 ampere alternator you have seen..... but you have actually seen that photo before.
http://forums.aussieveedubbers.com/viewtopic.php?tid=80709&page=1#pid762149
So how many times do you need to see it ???
