i have a 57 oval can i change the solid beam gearbox for cv still set up
lownsneaky - October 15th, 2010 at 10:18 AM
i have a 57 oval can i change the solid beam gearbox for cv still set up like an irs set up
rose - October 15th, 2010 at 11:14 AM
give Vintage Vee Dub they will tell you
ph 0297 891 777
vwsteve - October 15th, 2010 at 12:02 PM
if you weld in irs pivot boxes and swap it all over
lownsneaky - October 15th, 2010 at 01:25 PM
sweet anymore info
Birdman - October 15th, 2010 at 05:03 PM
You will need to buy aftermarket (or cut from an irs beam) brackets and borrow a irs bracket jig from someone.
Then have the brackets PROFESSIONALLY welded to your beam.
Then you need new spring plates, the irs arms, axles, cv's and a new box.
I have a complete beetle irs rear end and 1600L SSP box in marrickville if you are interested.
