Flipped transmission how to setup shifter rod
Caroneten - January 7th, 2011 at 02:01 PM
Hi All
Have got a flipped bus transmission in my baja kombi and trying to setup up the shifter rod to work correct. It has alot of play and hard to decide which gear you are in any advice to correct this. It currently uses uni s and a bend shifter rod are there any other options.
BJ
Ampdub - January 10th, 2011 at 02:51 PM
Ok not up on the whole BAJA/FLIPPED transmission thing, got me interested. has this been done before and what does it look like.
tassupervee - June 13th, 2011 at 07:21 PM
Have a look at the backend of any Formula Vee M8.
Try to avoid bent rods if you can. Use straight rods, supported with bushings and change directions with unis.
L8r
E
dangerous - June 14th, 2011 at 06:03 AM
If it is not 091 the pivot rod will slide out.
091's have circlips to retain this pivot, whereas 002s do not.
Normally the orientation and gravity hold it in place on 002's.
Otherwise, being indexed like that should pose no problems,
especially with a box that has the coupling hole on both sides of the selector shaft.
Another thing to note is, the case should be drilled to allow oil flow between the diff and gear case.
dangerous - June 14th, 2011 at 06:04 AM
What are you going to do with the 4 reverse gears?
Caroneten - June 14th, 2011 at 08:36 PM
Its actually coupled to a V6 in a baja kombi with reduction hubs.. I didnt set it up just trying to get some feel in the shifter. Have order a new shifter and replace all the unis currently in it. Hopefully have pics and updates here for you soon.
