Custom length axles
Peter O - January 24th, 2011 at 07:41 PM
As the subject line suggests I am looking for someone who can supply custom length 33 spline Chrome moly axles at reasonable prices in Australia.
Any one?
vw54 - January 24th, 2011 at 08:17 PM
is that IRS or Swing ???
vwo60 - January 24th, 2011 at 08:58 PM
IRS
Peter O - January 24th, 2011 at 09:04 PM
Originally
posted by vwo60
IRS
Correct
For a wide coil over shock suspension set up using Bus CV's and heavy 3x3 swing arms
Yet to measure but axles probably around 22 -23 inches
Lovebuggy - January 24th, 2011 at 09:42 PM
The Edge Products in WA
http://www.edge.au.com/
Edge forum http://www.edgebuggyforums.com/index.php
Also 22-23 inches would be too long for 3*3.
I am running 3*2 inch arms and only use about 18.5 inch axle clip 2 clip.
Peter O - January 24th, 2011 at 10:17 PM
This is a rail style buggy, I am not running a torsion tube so my original 19.5 inch axles are to short now with 3X3 arms on what was a combi torsion
width frame wheel track will be about 12 inches wider than stock beetle. I will widen the front end to suit.
Will try Edge and see what they say. Thanks
stoker - January 29th, 2011 at 07:09 AM
what do you class as a reasonable price???, and what diameter
HappyDaze - January 29th, 2011 at 07:30 AM
If you can't find what you want, send me a PM, and I will give you contact details of the bloke who can make exactly whatever you need.
Oh, if you are looking for 'cheap', don't bother.
RodPenrose - January 29th, 2011 at 08:47 AM
Peter , I keep the 20 1/4 axles in stock for the bug transmission and the 19 1/4 axles for the bus transmission for the 3x3 arms , I have these in
both the vw 33 spline and the porsche 28 spline . I also have the arms , and complete CV kits here as well , ROD. 02-42729920 .
matberry - January 29th, 2011 at 09:52 AM
And even Rods cheap one's are STRONG.
Peter O - January 29th, 2011 at 07:17 PM
Originally
posted by RodPenrose
Thanks for the response Rod
I already have some new 19 1/4 crome moly axles and a set of original Bus ones to. i will need something longer but until I set up the swing arms
tomorrow I will not be able to measure just how long I reckon they would have to be at least 21- 22 long as I want the extra width in the torsion tube
and the extra width of the 3x3 swing arm. I will call you when I have a measurment between drive plate and stub.
What do you class as a reasonable price ???, and what diameter
Stoker
I guess the answer is around what they cost in the US as postage is only around $40- $50 now days. Diameter? I am running Bus CV's so there is not
much point to going bigger than the spline as all the ones I ever broke were right at the spline it would be the weakest point.
If you can't find what you want, send me a PM, and I will give you contact details of the bloke who can make exactly whatever you need.rnrnOh, if you
HD
Nothing about building a modified rear end is cheap but my labour.
