gday, would like to know what ECU's people have used good and bad, when doing EFI conversions.Especially 2ltr kombi's
FOZ
MSII is good, versatile and popular.
I've used a Delco ECU fitted with a Kalmaker realtime board on a modified Type IV motor in a Baja. The delco ECU's are fitted to JE Camiras, VP/VN
Commodores, N13 Pulsars, N13 Astras and a heap of other vehicles both here and in the US.
I found it to be a really reliable and very flexible system, but it does require you to have a reasonable understanding of engine tuning as you can
change the settings for absolutely everything. That said, I had never even worked on an EFI engine before I fitted and tuned this one. Steep
learning curve! I plan on using this ECU on a couple of my other projects in the future...
R
Ive just got my 71 converted to MS2 extra code using Tunerstudio, It's good but its definatly not plug and play simple. Good budget option if your a bit of a tinkerer.
the best in Aussie is Autronic
I have a Microteck MX8
