I am looking for sombody that could post me some pic's of there wiring on the back of there wiper motor on a 1972 super bug! or tell me which colour
wires go where?
Took them off and didn't label them (big mistake).
Do the wires still have the colour coding on them? You be able to use that to connect them up.
Yep all the origanal colours are on the wires but i need to know which colour wire goes onto what connections to the motor there are five all together
and they have no markings with a colours or numbers?
so if somebody had the same setup they might be able to tell me wheir they go!
Their are two connections at the top, then two at the bottom and then one to the right in the middle of the upper and lower as you can see from the
picture.( hope that make sense)
here you go mate this will help you
http://www.thesamba.com/vw/archives/info/wiringt1.php
hi
done the wiring diagram, no good because there are no numbers on the moter, so if any body has got the same motor set up, can they please tell me
which colour wires go on which connection?
need to get it done before DOTVW!!!!
