Firstly, last exam finnished today of grade 12...freedom.
Now to business, engine is out, body is about to come off.
The question is how difficult is it to run stainless fuel lines, if you've never done it before, i've watched a few videos and read several articles
and have noted that the tunnel is the most difficult place to run the lines, also, for a bigger motor (1916 or higher).
What kind of additions do i need for the standard system, is it only a return/delivery line??
Are there any pre-cautions that need to be made, i have little knowledge on this topic.
Thanks,
Jeremy
yes it can be done but requires careful planning and cutting access holes in the tunnel and welding them back. Placement of the lines is important! so
it doesn't interfere with shifter rod, hand brake stuffs and other cables.
As for holding in the lines, probably good idea to copy what vw have done with the stock lines. Or clamping blocks like what you see under most
modern/semi modern cars
I plan to do the same thing eventually and also silver braze AN bungs/fittings on the ends of them.
you just need 2 lines, supply and return, for efi that is. only one line for carby.
Where can these be purchased from (links)? What sort of lengths are required and are there any ways around cutting into the tunnel. DO any connecters need to be purchased and what kind?
hydraulic places may have them?
ebay
http://www.ebay.com.au/itm/8-AN8-Male-Stainless-Steel-Weld-Fitting-Bung-/1706...
Be aware that stainless steel will work-harden [and break] if it is not well supported, and allowed to vibrate.
there is nothing wrong with mild steel so thats an option too and probably the better one.
Thanks guys, its a bit to consider, how do those connectors work, does anyone happen to have pictures of these on or being fitted?
Congradulations, in reality your freedom is now finnished and you can look foward to a life of servitude, on your subject, you will need to deceide what you want to actually want to achive, fuel injection, carbs, etc, etc. that will determine if you even need to change anything, if you want to change the line in the tunnel the only option is to cut access holes into it and weld them up after you have finnished as stated by a previous reply.
Freedom is the world of the month at the moment
What i want to achieve:
EDIT: After speaking to Nino of Bocchino motors, he has turned me, he suggested one of his 1850cc's motor that putsout 165hp. Its not only has a
decent power put its also prown to not breaking down.
Being able to put out a decent amount of power and be able to highway cruise at 100+kmph.
Engine will more then likly be a Pobjoy engine.
I have no knowledge in engine building and the pickup and feed lines involved.
looking forward to my knowledge being broadened.
If Stan builds you a engine he can guide you on the fuel line requirements, the 1850 CC motor with 165HP output is optimistic, to build any vw engine with that power is very expensive.
There are many options to choose from, and we could talk about it forever. However the 1850 comes in at a bit under 5 figures and is built with power
and longetivity in mind.
With that in mind now, i will also give Stan a call and speak to him in regards to this as well.
I would like to see the 165 HP reading on a dyno, like i said power does not come cheap and you can spend five grand on a basic motor, carbs for that
would cost two grand. had a look on the samba and this 1915 CC engine with no exhaust, clutch and running standard cylinder heads costs $4295US.
http://www.thesamba.com/vw/classifieds/detail.php?id=488765
You have a pic of the fuel line under the fuel tank with the hose perrished and broken on p1 of your members rides thread. Here you describe it as 'The fatigued connecter which had done 40 years of service' It's no connector, just hose that slips onto the steel pipe, take the hose off and replace with new VW hose (5mm) and bigger lines are'nt really required untill you have some real serious horse power, even 165 could run stock pipes.
Well in that case I'll be spending 25-30,000 on mine haha
haha so a stock engine is 5000-6500?
really? if so, thats ridiculous!
