I haqve original 15" rims on my '70 beetle. I scored a set of wider rims and they are only 14". Could I put the wider 14" rims on the '70 beetle
and what sort of problems would I experience if any? Both are 4 lugs.
TIA everyone.
it makes them quicker to accelerate but will make you rev higher at the same top speed compared to the 15’s.
plus they may not sit inside the guards which could be a problem
Like barls says, but also need to consider the tyres... I used to run 14 x 7's on the back of my 70, but because of the width and aspect ratio the
overall diameter of the tyre was virtually the same as stock and didn't really affect gearing.
But yeah - depending on the width and offset clearance could be a prob... make sure you check it carefully.
How wide are we talkin ???
You should check up on ther availability of tyres for the 14" wheels, I think that there would be a better selection of 15" tyres.
You just have to size the tyres right.
All the 70s and 80s 4 stud mags where all 14"
You wont get any 14s that are as tall as stock 165s but you can get reasonably close.
I ran with 185/70 14s for years, I wouldn't go any smaller than that.
Mates bug has 205/65s on 6" hotwires and they are slightly taller again.
Play around with a tyre calculator and see how the tyres compare to stock 165/80r15 tyres
This is a good one
http://www.1010tires.com/tiresizecalculator.asp
I had a set of 5"x 14" rims made up years ago and the only issue I had was 2 of them wouldn't clear the front calipers. Fortunately the other 2 would. Before you buy tyres I suggest you bolt up the rims to check clearance although they are probably wider than my 5's. Prior to that I had 6" x 14" and didn't have clearance issues.
