Hi All
I'm doing the IRS conversion on my Baja and read somewhere that the pivot brackets should be setup at a certain angle from the horizontal plane.
Anyone know of this? Something like 10 or 11 degrees. Just interested in checking it when setting them up.
BTW I'm using a brought irs jig.
If you are using an IRS jig then you should just bolt the jig on and the pivot box should be in the correct position.
Can you post a picture of what you're doing?
Smiley
Also, here's a good little thread with a few pictures to follow.
http://forums.aussieveedubbers.com/viewtopic.php?tid=76337&page=1#pid728784
Smiley
