Turbo build opinions?
baja_01 - August 18th, 2012 at 09:20 AM
Hi All
Playing around with the idea of putting a turbo on my 1776. Starting to collect parts. Bought a good TE05-12b turbo off a Saab 2.0L and now looking at setting up a blow thru system. Thinking maybe a single turbo prepped Dellorto 40mmDRLA or should I try duals? This is only going in my Baja to give it a little more poke.
Joel - August 18th, 2012 at 10:45 AM
What's your cam and CR?
bugzla - August 18th, 2012 at 01:30 PM
rrrrrrrrrr did you find that dell on ebay had been thinking as well but have gone draw through instead also try a 32dis they are available from the uk rebuilt to your specs if its only to be a small cc engine
baja_01 - August 18th, 2012 at 02:55 PM
At the moment running 8to1 CR with Engle 100 cam. Looking on Ebay. I've got a pair of 44IDF's. Was thinking of using one for the blow thru but going to build a stroker also so need carbs for it.
