Has any one here done conversions lower other than ej20 engine and has any one done diy flywheel and adapter plate, please shar some info, picture
Do you just mean smaller capacity like the little EJ15, EJ16 and EJ18?
few people have done it but may as well make it worth while, the bigger engines are just as economical and the same amount of work to fit.
Are you somewhere where it's hard to get conversion kits?
I got a friend in Egypt making his own as it's very exspensive to get one sent there.
Look at my build. Look at the pictures.
You have to do everything the same whether it is 1.6 all the way to 2.5
The 2.2 SOHC works well for cost and smooth economical drive. If I would do it again I would start with 2.5 DOHC. Anyway seeing as you have to do
evreything to fit the engine, whatever size, read my thread, and see if it helps to understand the engineering details needed. You will be spending
$4000 I estimate minimum to do the whole job, and maybe another $800 for engineering certificate to make it legal.
Mine cost about $6000 all up and I fitted it all myself. With outside engineered flywheel, adapter plate, sump, wiring, exhaust, radiator. I did the
engine mount brace myself.
If you go EJ, as said above- go 2.0 or 2.2.
If you are refering to the earlier EA series engines then they will cost you almost as much but there are some advantages over the EJ, not many but
some.
The EA81 is the one to get not the OHC ea82 with its array of belts for little benefit. The ea81 with a weber 32/36 is a very simplistic engine,
compact and light. So little chance of having weight issues depending on where you place your radiator etc.
The EA series has limit with modifying the intake as a water channel runs along under the manifold as part of the manifold. really the intake is
primitive. Also the engine needs an approapriate cam and few other improvements whereas the eJ does not.
But if you want a compact easy to maintain engine it isnt such a bad choice. EA81 nuts like me love them because its simple old school. Otherwise- go
the EJ route and get to know the engine well. It will serve you better than most engines. Go Subie!
here ius my ea81 without carbie. about 105 kgms.
see below
EA-81: 1,8 liter, 100 to 110 hp, about 85 kg(187lbs) dry weight
EJ-22: 2,2 liter, 130 to 160 hp, about 120 kg(265lbs) dry weight
EJ-25: 2,5 liter, 165 to 200 hp, about 135 kg(298lbs) dry weight
EJ-33: 3,3 liter, 225 to 275 hp, about 160 kg(353lbs) dry weight
Yeh likely less than 105.
That adapter plate weighs a bit.
I was thinking wet weight with all accessories. I needed to know for that time I was to replace the 1916. I lift mine out by hand too. Last week I
did it again. Then lifted the auto and transaxle with Torque converter. That assembly was less weight than the ea81 engine. No wonder they use them
in planes
Thank you tweety btw lot of great information where were you all the time???
thanks mnakandala but when you own a "bitza" thats the nature of the game. When I took out the VW 1916 and replaced it with the ea81 it only left
the T3 auto tranaxle as being relevant to this site. Which still has helped me immensly I might add.
So I scroll thru here often to see if I can help others just like they have helped me. But engine wise I get info from ausubaru. Then there's trike
forums that have moved to Facebook. So its busy ownign a bitza lol
