Just picking some brains.Has anybody ever had anything to do with sticking a 4 cylinder diesel into a VW. If so, what type of engine was used and any info on an adaptor plate used? Was thinking maybe a Mitsubishi from a Pajero.
There used to be a bloke in Port Macquarie that had a diesel Golf motor in a baja.
The south African t3 kombis could be had with 1.6ltr diesel golf motors. So the bellhousings are a factory part if using a kombi box. I am under the impression that the block bolt pattern remained the same throughout the 90s, so you can even put the 1.9T in there.
Thanks-would be using a Bus auto trans-so that will work.What does a 1.9T come in here? I remember reading some years ago that some body did an adapter plate to fit a Mitsubishi diesel from a Pajero to a VW trans.
Mk IV Golfs and New Beetles.
Thought there was a UK version where they used a Fiesta motor.
Maybe confused
Have seen the VW diesel conversion kit on eBay.
Just did a Google search and a good write up on the Samba of a conversion to a 1973 Westy
try John at VW conversions. He has 120 adapter plate to suit VE engines. Huge range. Google it.
G'day all Todd at subarugears is developing a Subaru diesel conversion check out subarugears site or FB thread
ernie
Thanks- I'll get onto it.
