EJ20T turns over but wont start
62ekspecial - October 26th, 2014 at 01:17 PM
Hi All
Just got my EJ20T in the beetle.
I have wired it up with the full loom from the donor car. Tricked it into thinking its in park/neutral. No connections to gearbox.
The engine cranks over and the fuel pump runs off the original loom. The ignition relay also "clicks".
Pretty sure i have every ground connection earthed.
All ran fine in the cut a couple of months ago.
Any pointers greatly appreciated
Tristan. Melbourne
vlad01 - October 26th, 2014 at 03:31 PM
check for injector pulse and spark. see which are missing.
62ekspecial - October 26th, 2014 at 03:37 PM
Sorted
the bosch fuel pump needed priming it was just pumping air.
Any good threads on cutting down looms?
vlad01 - October 26th, 2014 at 06:36 PM
make em from scratch I recon.
