howdy
just wondering, who and where are doing all these custom crossmembers to fit your suby,holden and whatever engines?:thumb
Depends on what you're fitting it to. The Subaru EJ20 conversion into the Beetle doesn't require any crossmember. You just use an adaptor plate and new flywheel. The Subaru motor hangs off the transaxle the same way the VW motor did.
mine is made out of 2" pipe to fit my holden motor!and it is just adapted to fit the VW style engine mounts
rhys
I'm guessing most people doing these conversions are pretty handy and would make them themselves.
Volkscare in Adelaide make them for the Subaru -> T3 Caravelle/Syncro.
Very nice crossmember too !
Call Bob on 08 83691233 BH for info and pricing
Crossmember?
or rear engine mount just a support to hold the engine in!
peace
rhys
I made my own, if you are sticking a subie EJ into a kombi you can copy my design, (email or u2u if you like)
Jenny, the EJ20 is a heavy little sucker (~140kg), i sure as hell would be putting something else under it
- there isnt a hell of a lot of thread in those adapter plates either, they are only about 12 mm thick ...
Hmm, guess that's just one more thing I'll have to discuss with the certifier!
Can anyone with the Suby/Beetle conversion post us some pics of the bracing?
not subaru, but still relevant...
Those bars look great :thumb:thumb
Crikey! I understand that your Baja cops a flogging but that sort of set-up would be overkill for a car, wouldn't it?
Nice work though.
Would this sort of thing be suitable
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=DRC0006&c...
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=DRC0007&c...
Sort of but it still isn't helping out the bell housing any. If you are going to run one of them then you would also want two straps on the
transmission as well.
Man those things are $$$$ for $275 USD plus postage I would be getting a custom setup made.
Brad, can you give us some more detail on the bellhousing trans,ission straps?
Something like this?
http://www.empius.com/t/transsupportsmounts.html
Yeah that is the sort of thing. You still need to brace up your rear forks though if you are just going to hand the EJ20 of them.
Have a look in a Subaru and you will see the EJ20 is not designed to hand of just 4 bolts from the block.
Hi all. Found this picture of an IRS bug chassis with bracing and engine mounts for a Subaru EJ25 motor.
http://www.geocities.com/peterwood732/buggyproject/FloorPan.jpg
Quite an informative site. Here's the index page
http://www.geocities.com/peterwood73/index.html
