Ok here it goes I was toying with the idea of a mid mounted V8 engined bay early or late bus this is only the research part of the project.
The reason I was contemplating this conversion is to get around the gearbox problem associated with higher output HP. I know I would have to install a
differential as well. The intended use for this vehicle would be drag racing, I don’t want to street register this vehicle but will need to have it
ANDRA inspected; I’m no tech head and only a novice racer. What would be involved in mid mounting a V8 engine any information will help I don’t
need to have access to the rear section of the car for passengers so I was thinking the whole of the back section could house the engine gearbox and
differential. I have spoken to a guy who installs wheel tubs and diff that’s fine. Is there enough room for the V8 to fit in the back with gearbox
tail shaft and diff? I know CBB has a mid mounted V8 but it is stretched and I don’t want to stretch the bus. Any info would help.
PLEASE remember this is only the research part of the project.
wacked1
Hans Klaack had a mid mount Toyota V8 in a twin cab ute a few years back, dont know if he still has it. they used to be at this address 6 years
ago.
Klaack Motors
2A lackey st
Fairfield NSW
I've heard of it being done. Have'nt seen the conversion tho.
Ultimately, you'd build a "half chassis" car. So make a spaceframe that just bolts up underneath. I don't think you'd have to
stretch a kombi to make the conversion work. There should be heaps of room.
I'd run a powerglide feeding directly into the diff and tie it all up like a transaxle with a 9 inch IRS conversion and double a arms. However,
if you could get a driveshaft in between the box and the dif' I'd keep it live axle and run a 4 link set-up.
I think since you'll have to scratch make everything the possibilities are virtually endless. However, I'd look into Japanese quad cam
V8's and using a turbo/s set-up as opposed to an old Aussie cast iron donk.
ive seen one in a strech kombi but i didnt look real close
Hans Klaack had a mid mount Toyota V8 in a twin cab ute a few years back, dont know if he still has it. they used to be at this address 6 years ago.
Klaack Motors
2A lackey st
Fairfield NSW
thanks guys, will give Hans a call.
yup, can definitely be done, seen some pics of some 70s drag racing busses with that setup.
CBB also have a Mid mounted V6 in a dual cab. Not stretched.
The V8 will sit right up behind the front seats tho.
There is a bay kombi going around the UK with a BMW straight 6 mid mounted in it. Before I new what it was, I was waiting at a set of traffic lights
on the way to a show (Bristol) and saw this 'thing' go around a roundabout.. It sat about an inch off the ground. I took off from the
lights expecting to see it just around the corner, only to find that it had shot half a mile up the road!
I have seen a photo of it on the web somewhere. I'll try and find it one day and post a link here.
Andy.
[Edited on 24-2-2004 by type2nut]
It definitely has been done. There was a bay (non-stretched) with a mid mounted V8 going around Melbourne in the 70's.
My brother saw it up close so I'll see if I can get any info from him.
cool guys, pics would be a big help.
thanks
wacked1
'Research' = silly questions. No disrespect but sorry wacked, but if you have never been drag racing or don't have the engineering skills, maybe you are aiming too high with a project such as this
sorry I don't know any details of this bus
Mate best bet is to get a hold of the ANDRA handbook and have a talk to a few of the guys. If you are not going to register it. I THINK you will not
be allowed to run in street class. Which will put you straight in with the faster cars. I do not want to try to Quote any of the rules as it has been
a few years since I raced and then it was mainly bikes. But if you are not going to register it it would be a straight forward project. Just follow
the guidlines they set you from the start and everything will be sweet when you go for scrutinering.
Have fun
Andy
Oh and as with all projects the more you can do yourself the cheaper it will be in the end.
I deleted my last 2 posts as it was getting a bit childish, no probs with VWCOOL just please stick to the original post
wacked1
Here are a couple of photos to show that it can be done. And with 4WD too. Now that beast would put my Syncro to shame!!
More links when I have more time to hunt them out.
Andy.
http://www.vanfest.org/2003/vanfest/modeng.htm
dan said
...make sure it's a Gen III!
wacked1, if you go to http://www.custombugsandbuses.com you will see the
strectched bus that 'dan' posted pics of. mike did this set up to take the crew and drag car to meets.
but i know there is a shit load of work involved, so you would need plenty of moolah or a lot of spare time and tools.
if your not rushed i am sure you will see it at the nationals. i kow it has been to other shows and won trophies...
Thanks guys, I've seen the CBB stretch up close at last nats and it's fine. But don't want that sort of thing spoke to ANDRA tech today
and got info needed. not much at all I was more after the thing type2nut and hotrodmatt
refered to.
thanks
wacked1
[Edited on 25-2-2004 by wacked1]
