Like the one in this photo
[Edited on 3/4/2005 by seagull]
Ebay. Should be a few on there.
got one , thanks
got one , thanks
are these pully's interchangeable? I have an EJ20 TT, would a pully from a EJ20T or NA EJ20 also fit?
Should be the same.
Did you get it on ebay???? I might like one too please.
a mate had this , and there was some spares so he gave me one .
I would say with removing the cast iron pully and the cast iron alt bracket .I lost about 5kgs
well worth the change
if you need any info and performance bits for subies go to...
pms.net.au
performance motorsports website.. aust wide
robin has all the goodies and can make your subie or subie pwrd vw go real real real fast!
Yes robin did my wiring or my ecu ( well andrew did ) good turn around
yep all good.. been goin there for years.. no gettin stuffed around. why would you take ya subie anywhere else.. me thinks anyway
MMMM me think you work there ?
no dont work there..
just known robin for a long time...
Ok cool , you running a subaru ?
yeah only in my subie brumby!!
you know daily drive hack..
If you're not using the power steering then you can fit this kit, which only has the crank and alternator pulleys and belts, $279.
http://www.alldayperformance.com.au/prod23.htm
If you only want the crank pully then they sell for $239 here
http://www.modyourcar.com.au/product_info.php?cPath=7_52&products_id=2073
[Edited on 28/4/2005 by Jenny]
Mike, that was covered in this post
http://www.aussieveedubbers.com/forum/viewthread.php?tid=31275
Thanks Jenny.
but what is that billet/aluminum gold/yellowish thing in the pic right under the alternator? i know that didnt come on an sti...........
looks trick
sorry I dont know what that was for ?
