First problem
No dash light ecu check light . ??
Second problem .
I have power at the fuel relay but the ecu will not start the pump .Have checked the pump it works fine/ changed relay /wires are correct , just
nothing switching it on ??
ideas please , cheers seagullnn[ Edited on 17-7-2005 by seagull ]
Hi seagull,
sounds to me like you have a ground problem. The check engine light is connected to ignition plus and ground from the ecu only. If you got plus from
the ignition, you have no ground. Check your ground to the ecu.
ecu to check engine light is b 19 (that is the ground connection of the light)
The fuel pump relay is connected
ignition plus
d 12 and b 23 to the ecu
and to ground
Maybe I am wrong,
hope you find it. Okay ground is American English for you that is earth!!! Sorry I am more into American English.
[Edited on 23-6-2005 by subaruboxer]
I concurr.. sounds like a earth....
make sure you have earthed your engine block well. I had a few early on who really wanted a good earth not provided by the VW setup. Just ran one from the inlet manifold to the body.
Cheers guys I will check the above
One thing around the wrong way will also feed back into the computer causing problems that dont seem to make sense.
Again that is an earth issue. There are alot of earths for these motors..
Matt
Ok ran anther earth from motor to battery
ok eng light still does not work , has power now still no light , globe ok .
is there some thing missing to triger the relay ( shown here )
Did u do "Ctrl Alt delete" yet? lol.
Sounds like a terrible problem mate, but im sure u will get through it okay. GOodluck
wires are
red ( i have power )
black / red > to fuel pump
purple with silver dot > to ecu
Cheers :beer
I need the force :vader
Does there need to be an earth there....arnt the fuel pumps earth triggered ....its not microtech..shame! I am a friggen expert there!
Matt
Its shitting me the same Matt , I tell you I am going to hit it ( !!!!!! )
ARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
tryed an earth no go , its some thing silly I would say
Seagull,
your fuel pump relay is missing one plus (+) wire, it got to have ignition+ and permanent+ . If that is said wrong again,
it does not matter. I hope you understand what I am talking about. You need a wiring diagram!
cheers Mate , I had the wiring done in the over east as I could not find a diagram for a 96 ej20 N/A motor , the ecu has three plugs .
thanks again for the above I give that a go tonight .
Hey seagull,Check relays.Deffently does not sound like a earth problem.IF you have power check pumps are working. Also check ignition switch.After all
this checking,if you have more than one relay swap them around and see what happens.JVLRacing
Hmm looks like all my posts have been lost..
Ohh well, my last post was that I found a scan i did a little while back of the EJ20 ECU connections from the liberty book. its located at http://users.hunterlink.net.au/~ddat/conversion/Ej20.gif
Andrew.
Yes Andrew I had a reply to the post you made .
I found if I ran power to the green wire on the brown relay the motor started and then stoped , just a fire
I did a check on the earths they are working , just no latching of the relays .
Col if your can I would gladly buy you a beer to have a look at this please .
I had the motor light up 3 flashes then 9 fast flashes , I need to find out what these are telling me
this is the side that the lid comes off the ecu
shot of the other plugs at rear
top of ecu
I also made a post on this yesterday, aw well, here i go again.
The fact you got a fire by putting a hot wire on the relay suggests the ignition wiring is not hooked up correctly.
go to the relay pack, and follow the light green wire back to the diode, it will be a small black plastic thing taped up in the loom, kinda like a
connector. it will have a yellow wire in and a green wire out.
hook your hot wire up the the yellow wire, and tell us the results.
Col
btw
There is no code 31 in the manuals I have, so this could be a JDM or later model specific code.
Code 31 is the throttle position sensor (open or short circuited)
ok , I am back to the shed to find the above
Col , I have followed the green wire from the brown relay >there is no plug or diode on the green wire is goes straight to the ecu ( shown as number 9
) on the fist photo of the ecu .I can not see a cut in the wire .
I must say I am lost :beer
hey guys , what if the ecu had a remote type key start from factory ? would this stoping it or would the removal of the starter and mods to the wires get around this .
is there any way of finding out what the ecu is by the numbers marked on top as per my photo ? ( import front cut )
if the auto ecu is removed can the motor ecu still be started ? ie may be the motor ecu thinks it in drive and will not start
I must be fighting the VW god in my shed some how telling me not to go to the dark side :vader
Hmm guess the late model import jobs are done differently
This doesn't help you any, but this one of the main reasons I pulled out my EJ20 and replaced it with and EJ22. They are far easier to get parts and
bits and pieces, knowledge and acurate diagrams are easily available.
you know there was an EJ22 with loom and ecu in the quokka couple of weeks back for 1200..., could still be available.
and all your adaptor exhaust etc will fit + more torque..
Col
