A faulty fuel pump, then a nail & tech screw in the left rear tyre, then a loose earth............we overcame all that to then have the clutch have
the final laugh, slipping at 6000rpm it was all over, but still, 131.9kw @ the wheels on 11 pounds boost without a pushrod in sight! (is it a deisel?)
change of clutch will allow it to be finished off & reach its full potential. Once again, fellow Pastizzi eater Nathan from the Throttle Shop worked
his magic & Matt says that it drives better already.
Took a few picks, enjoy.:thumb
regards
Jak
http://www.thesamba.com/vw/gallery/pix/214780.jpg
http://www.thesamba.com/vw/gallery/pix/214784.jpg
http://www.thesamba.com/vw/gallery/pix/214783.jpg
http://www.thesamba.com/vw/gallery/pix/214782.jpg
http://www.thesamba.com/vw/gallery/pix/214781.jpg
Damn those animals are going to surprise people.
I cant wait to see the final results. Well done.
I want one.
How big is the smile Matt ?
Its a joy to have another victim to the darkside:vader JVLRacing. P.s Matt those white AVS rims would l:thumb:thumbk fat on that car!
[ Edited on 29/6/2005 by jvl054 ]
The car screams.....twice as quick as it was,partly attributed to an air leak on the cooler side of the turbo we didnt know about till a couple of
days ago. I have the new clutch on the shelf that Mike from Cbb made, so when I have a clear day it will be done and then up goes the boost. Nathan
has set an 18lb limit on the computer in case I go silly before It returns for its final tune.
The car was at 10lb of boost at 2000rpm and torque was a straight line.
Good stuff mate! Looks great....bet it goes better. Not too long till mine is on the dyno too :thumb
what transmission are u using for yours matt?
also have yo and jack gone head to head yet? :P
Anthony
Anthony, please tell me you havnt forgotton the countless times I have told you that I have a ssp with welded 3rd and 4th and a super diff. Jak has
similar.
Jak has the potential to make more power due to his t5. My vf24 has more torque and spools up quicker. If only Jak would embrace the boost, his car
would make ridiculous top end power. Rizzo I'm getting you a controller today!
Matt
The Rizzmaster will up the boost one day I am sure..... look at his past - his engines continuously got bigger and more powerful, and then he went Subie turbo. So its truly only a matter of time I reckon.....
Inspiring pictures!!
Jak's car looks lower at the back and higher at the front then Matt's car, or is it just an optical illusion?
Mine is a 68 body, jaks is a superbug...different lines.
ahh sorry matt. u told me that?
haha
well yeah. my memory is like a sieve
(alcohol and herbs dont help with
that)
Anthony
also i was just wondering. with you intercooler placement matt.
wouldnt that effect the dyno figures. as there wouldnt be any air flow going over the core??
Anthony
You missed the 2x 9inch thermos in the box....it works ridiculously well! Drops intake temps down to 10-18 degrees.
Clutch is changed..just got to weld up the exhaust to the new dump pipe I got....dyno again tuesday..maybe?
Matt
Jak > Matt ? please I just about to machine a fly wheel up with a subaru center what size fly wheel are you using and have you a run down on the
clutch your using as well .
cheers guys , seagull
Our flywheels are 215mm units & the clutches are custom made items by Mike at CBB.
regards
Jak
New clutch is in with the new improved boofy exhaust and dump pipe....I seriously think the clutch was slipping the entire rev range, because I
thought it was quick before. At say 3000 rpm in second cruising down the street, you stand on it and and after it stops spinning, the g-forces hurt
your head...
I am nearly afraid to turn the boost up..lucky that was nearly, although seems to be just on the lean side due to the dump pipe and less restricted
shape of the exhaust. Add a touch of fuel here and there and I'll try 16 psi...
Got to go drive some more...
Matt:P:o:P:o
good to hear! cant wait to see it on the track!
alex
