Do not know how deep it is...looks a bit shorter..see header flange..
http://www.hyperflow.com.au/techsump.htm
Hi Matt
Its hard to judge but it looks about stock depth compared to the headers. Maybe they could make a short version for all us guys, we should all
bombard them with requests?
I just sent them an email, lets see what happens.
Yeah looks standard length to me. Also looks expensive. Any idea on price?
Yeh i agree Mike,looks standard depth to me as well.I cant see it working any better than what i have done already.L:P:Pks shiney thow:thumbJVLRacing
Hi,
still have the mould for the flat sump and still have the parts for sale.
Many discussions here in the forum, but nobody comes to an end.
Don´t mind sending to Australia.
http://www.bugat5speed.de
So, fact is, that the trader who was interested now obstains from doing something.
Still am looking for a dealer for my products. Freight is not that much. Can send upto three sumps in one package. Costs are 82 Euro for such a
package (takes 1-2 weeks).
Price will be without German VAT (250 Euro each).
Perhaps two or three of you make a centralised buying.
Can´t do more at the moment.
is there > was there a link to the cast units ??
have i got the right page??? blame google translate for dodgy text....
Already before approx. 10 years it was clear for us that the evolution of the WBX engine could be actually only OHC oHC-oder the DO HC-double-piston
engine of the Japanese manufacturer Subaru. After 100.000 km with a Legacy, even driven, one at that time already wished oneself this everyday
life-suited and matured engine into the own 1303.
Image At that time before the change it back-frightened that there were still too few specialists for things such as expanders and adapted wiring
harnesses. Fortunately there is further idealists, which recognized that the Subaru subaru-Boxer reliably 100mal better the beetle fits, than any row
engine (even if it originates from the house VOLKSWAGEN). It formed its own small scene, which concerns itself with the production of special parts
and the installation of these engines. Since with all changes seen so far deep, optically extremely unattractive, or shortened oil pan had held from
the installation of a "Subaru", one took forwards for remedy to provide itself. Due to earlier model construction amateur driving and other cast
parts a 2-piece oil pan from aluminum casting developed.
This tub is 5 cm flatter than the original and permits oil contents of 4,25 litres. Most shortened oil pans are about 3,5 litres of volume. The tub
has cooling fins on the lower surface, those the engine also from down revaluations. The main use of the ribs is however the substantially reduced
heat development in the engine. Tests at a turbo engine with plentifully HP, built into 1303 brought the result that the water temperature sank at
first attempt by 10 degrees. Inside 2 bulkheads are trained, which prevent a way sloshing of the oil in fast driven curves. The cultivation is
absolutely problem-free, since all drillings of the original were taken over. The original dipstick can be re-used. Shortening the original oil
sucking in pipe is not large history and can by us be taken over if necessary.
Subaru Oelwanne
* 4.25 litres of oil amount of filling
* 12 cm overall height
* reduced heat development
* Bulkheads
* easy assembly
* optical revaluation
Price:
295 euro
Supply takes place including the necessary socket head screws
http://www.bugat5speed.de/cms/images/stories/content/subaru-oelwanne-extrahie...
The thing is...there are not that many of us actually driving around on suby vw's. The ones that are, either are not that worried or have already
done something about it. It is just interesting to see what products are out in the market place and their pricing.
For me, $600++ for a sump on a motor that costs $800, that I do not really need is not an option. However If a cast alloy sump like yours was
available for $350 I might get it.
Your other parts look really good, although due to the amount of worked wrx's here, there is alot of competition and parts are relatively cheap.
Boofy.
Matt
OK, at 250 Euro each and 82 Euro postage for 3 that makes 832 euro landed for 3. At the current exchange rate (1 Eu = $1.59) that's $1323 AUD, so
$441 each.
Like Matt said, if they were about $350 each then I'd probably get one as well.
My calculations were a bit off, thanks for the official conversion Jenny...would have to not insure them, send them express and make the cost under
$200 total otherwise they will look them up and charge another 13% gst and import duty. Adds another $50 roughly.
I havnt looked under the 914 yet, although I think the mid mount is quite high.
Matt
I just bought the metal to build my own sump, it cost $39.50 all up & thats cut to my measurements!
Fantastic!
In saying that, those sumps look excellent, but most of us are doing the conversions on a budget, so when my engine cost $850, theres no wayI'm
spending half that on a sump.
regards
Jak
yes Jak I agree with you >man the buggers want 2K for a motor over here in Perth.
ok guys,
make a suggestion.
The first two private person, who make a centralized order for each one oilsump will get my sumps for 320 AUS Dollar each plus freight. Based on the
current exchange rate it is 200 Euro. The order for 2 sumps must come by mail. I need your address for the invoice. Payment is in advance.
You have to arrange on your own, with whom you order and how you clearify it with money. I want to have the money for 2 sumps plus freight in my bank
account and don´t want to care for this at all.
I want to show you guys how a good oilsump is looking and want to get into your market. That´s the reason for the price.
Once more: The price is only for this first order of 2 sumps.
mail to : info@bugat5speed.de
Cheers Martin Bug @ 5-Speed
i'll finally have my modified loom for my EJ20TT in 2 weeks and will post pictures of it with the shortened sump bugat5speed produces on it then.
OK, I'm up for one, so if anyone else in Brisbane QLD area wants the other so we can share the freight then please let me know...
Jenny - U2U sent!
there postal service is very good , I use it for work all the time . 3 days for 10 kg package
bugat5speed,
please check your email
72RSbug,
I just got a ej20tt in a 914..went to talk about the turbos to the guys at MRT and they told me to throw away the twin set up...constant computer
problems and massive lag on the transition from turbo to turbo. The only aftermerket ecu set up is about $5000 and they have only found one that will
do it properly...prob motec.
I am consideriing keeping twin set up although haveing them the same size and independant like 996..with twin intercoolers.
Matt
you have any photos of this matt ??
picking up tuesday, I may even be able to use the sony for the pics instead of the phone...I know you all love my phone pics.
Matt
