hi there at the moment i am looking for expressions of intrest i am looking at selling my beetle, its a 74 super bug with factory rag top so far motor
is in and crancks over does not fire as it needs a new ignition module its running a new microtec computer with hand set gear box has been moved
forward fierwall cut and moved forward radiator is mounted it needs water pipe and exhaust has porsche wheels fully ajustable coil overs from v force
has two fule pumps in the front and surge tank intercooler is mounted in box with thermos like (boof2332) can not think of anything else at the moment
cheers chrisnn[ Edited on 30-7-2005 by IN THE WEEDS ]nn[ Edited on 30-7-2005 by IN THE WEEDS ]
$$ and pics? How much more work to complete?
Whats happened Chris??? How come you are selling????
At least go to ems and get a module, they are only $115. I will help you get it started to sell it if you want.
Matt
That'd be good Mat. Interested in hearing yours and Jaks opinion.
I've seen the car, and from memory is pretty neat. The motor is the same as ours..from SSS and it just needs an ignition module to run, Not sure what
exhaust etc he has made up although everything else has been done right...
I'm not far from there and can pop over with anyone who is unfamiliar with the setup.
Matt
yeah, what does it need for finish/rego? I assume it is a 'round screen' car?
hi there i for got to mention it has a single side plate box with custom built brass button clutch will try to get pics on the weekend
looking for between $6000 and $7000 selling as due to the new laws involving p platers i am unable to drive it also some financial reasons
Would you consider selling parts individually???
Paul.
6-7 grand..thats a good price...
as already asked, what is needed to complete. and what brakes are on it? also which porsche rims, microtech ecu .etc?
Anthony
hi there all the car needs a ignition module plumbing between the radiator and motor an exhaust gear box mountthermos to both intercooler and radiator wired a shifter and join the throttle body to the radiator brakes are still disk brake front and drum rear the wheels are cookie cutters computer is a microtec LT8s with hand peice will post pics on the weekend car needs to be sold completenn[ Edited on 27-7-2005 by IN THE WEEDS ]
just put a price on it, looks like a good project
add the bits up , would save some one lots of time as it all there
Go to a wreckers and pick up some ignitors from a toyota camry. We just got 5 from the wreckers here in Darwin for $50.
Toyota ignitors are more or less the same from the lexus v8, soarer, camry, seca, landcruisers etc, and are very good quality. Oh, and they'll work
with a microtech ecu.
I use an EMS one. They are the cheapest new one you can get for about $115...that you know works. They are at Smithfield.
Not much to finish this baby.....1 week collecting little bits and pieces and then a weekend on the tools.
It will end up costing less than some vw performance engines.
Matt
ok how wants it $6500 you can take it
yes it is curve screen
what is done to the transmission? would it handle the ej20t..
also...are you able to find out how much to stick it on the back of a truck toperth?
Anthony
easy $780.00 via rail
looks intersting can u get me some pics please?
email kombikid@tpg.com.au
rhys
If anyone needs a hand with the injection, I can get this baby running....Become a microtech master I have. Its all the little things like fuel pumps,
radiator, thermos etc that have been done that end up costing over $1000
Glen, you cannot win all arguments until you have your closing argument, so sell your 1916 engine and you will be able to buy one of the quickest cars
you will ever own!
Something for everyone to ponder on this beautiful Friday.
me thinks vwcool will/does/ has in the past, owned quicker cars !!!
This would be a great project to buy.................maybe JVL should buy it, at least he could then start racing. :kiss
Now Craig, I said one of the quickest cars. With 16 pound of boost and sticky tyres that little super will do 0-100 in about 4 seconds and in the
12's for the quater. Thats engineered and street registered not like 90% of the cars at the drags last wed night.
I do not know what VWCOOL has owned or will own, although if thats no the quickest, it can not be far off....and all for under 10k
Hugs and kisses
Back on topic...................Chris any pictures yet?
pics will be tomorrow,chris and i need to move some cars around so to get it out and take happy snaps,,,,
cheers....:beer
hey
will anyone do work to finish it to make it driveable?? if so how much would this cost maybe u could boof?? im very interested if someone would get it
running an pics would be great!
rhys
Dude,
Ignition module $115
Radiator pipes from front to back, clamps, mounts and rubber hose....$200 tops.
Not sure if he has run fuel lines yet...and we can run it without a swirl pot initially to get it started.
Exhaust...a couple of bits of straight 3 inch 1x45 mandrel and 2x90 mandrels and pick a muffler. I have a dump pipe already... and ill weld it
up.Total $250
A few other little things....not much. I would have to go and look at the car, although if you got the stuff together, apart from the time consuming
bits like welding exhausts etc....you could be driving it in a weekend.
I'll show you all the microtech crap so you can sort it if there is a problem later, or have to pull the motor.
It wouldnt be more than $1000.
call me 0416115993
Matt
where is sawtell?
HI boof, Sawtell next to Coffs harbour.20mins from my door step.JVLRacing
