Subaru cable linkage set up
seagull - November 2nd, 2005 at 01:11 AM
I have been ask a few time now
How do you set up the linkage on the subaru as to get full throttle from a vw peddle .
Here is how my set up is
I use a small bearing as my pivot piont .
I also mounted the switch for the auto kick down on the braket at the same time , small tab weled to the subaru cam linkage
works sweet as
[ Edited on 1-11-2005 by seagull ]
seagull - November 2nd, 2005 at 01:13 AM
Pointing to the pivot point
seagull - November 2nd, 2005 at 01:14 AM
side
Jenny - January 12th, 2006 at 08:52 AM
Nice work Neil.
For those of use with gas pedals (instead of motor bike twist trottles), another alternative is to extend the arm on the linkage at the throttle pedal end, so you get more cable pull for the same depression of the pedal, as per this post http://www.shoptalkforums.com/viewtopic.php?p=680516#680516
Jenny - January 13th, 2006 at 01:23 PM
Or you could do what Hellbus did and extend the throttle body part http://forums.aussieveedubbers.com/viewtopic.php?tid=38417&page=6
seagull - January 14th, 2006 at 01:36 AM
yes it works well .
I have made a few for cars now , just to fill my need to fund other projects
I am making a roller peddel now for my subaru toy .
how is your carcomming along Jenny ?
flat_iv - January 14th, 2006 at 04:14 AM
I just removed the ramp on the back of the pedal. Removed the small tit on the back of the pedal stop. Then bolted a piece of delrin underneath the pedal to ride on the roller. I now have full pull of the throttle cable on the large throttle body cam.
Jenny - January 17th, 2006 at 12:20 PM
Hey Neil, check your u2u for the saga...
boof2332 - January 19th, 2006 at 06:48 AM
I never had a problem....the motor came with about 60cm of cable in the steel cable tube. Simply have it doing the 180 degree turn like the subaru, then made a bracket to hold it in this position and joined the cables. Have full throttle movement.
Matt
flat_iv - January 19th, 2006 at 01:54 PM
Different Suby's must have different cam diameters.
