intercooler etc
DIY-DUB - January 3rd, 2006 at 10:11 PM
what do u guys(and girls) think about my idea of inverting the firewall to have an intercooler under it above the box running thermo fans and ducting
from below? to suck air thru it? its achieveable in my opinion and sever drop in interior space ISNT an issue either so other than that whast your
views?
helbus - January 3rd, 2006 at 11:38 PM
It's a great idea. Can't wait to see pics of the install. What timeframe are you looking at until it is ready?
silverbullet - January 4th, 2006 at 07:59 AM
i have done some thing similar in my conversion i have move my fire wall 15cm forward and it sits behind that. i managed to fit a 50 x40x 8 cm
intercooler in there tight fit though. I duct all my fresh cool air from scoops in the side of the car through the car and into the new parcel shelf.
Works great. No need to run a thermo in my car keeeps temp around 40 degrees.
jvl054 - January 4th, 2006 at 02:36 PM
Originally
posted by silverbullet
Yep great idea!!!Thermos just a waste of time and money:thumbJVLRacing:thumb
pete wood - January 4th, 2006 at 05:08 PM
I guess you mean an air to air intercooler.
Well the bad news is, Air to air are less effective than water to air. You are better off using a Liberty RS water to air intercooler and running
pipes to a small radiator at the front of the car. This also means you can fill the water reserviour with ice on track days for even lower intake
temps.
All the serious competition drag cars use this set up with dry ice for the ultimate cooling.
Added to this, rear mount radiators/intercoolers are generally compromised in some way. Trust me I know cause I have a rear mount radiator, it works
ok, but a front mount would have been so much easier as the air supply at the front is much bigger and cooler with less turbulence and often no
ducting needed at all.
JVL,
I'm kinda surprised you think this is a good idea given your bonnet/radiator/intercooler setup.
DIY-DUB - January 4th, 2006 at 05:18 PM
ok so going with the air-water option do you believe there would be sufficent room for both a radiator and intercooler, installed in the spare wheel
well like how jak rizzo has done, so it sits flat with a sheet above where the standard spare would sit and infront of the frame head.
71superbug - January 4th, 2006 at 05:22 PM
wouldnt mounting the intercooler at the front of the car produce heaps of lag due to the distance it would be away from the motor?
Easiest way seems to be to have it in a wing like REUB does.
or could you have two of the small pwr type radiators (one under each rear guard) which feed the intercooler with its air? (for water to air setup)
Anthony
GTMac - January 4th, 2006 at 06:42 PM
Only the radiator for the air/water intercooler is mounted at the front, not the actual IC itself. I have both radiator and IC radiator at front in
spare wheel area, but yes my car is also a fastback so different space issue.
Go the water/air IC in my opinion.
Volkswagenboy - January 4th, 2006 at 06:54 PM
What about twin inercoolers under the guards?
jvl054 - January 4th, 2006 at 07:32 PM
Originally
posted by pete wood
temps.
JVL,
Why!!!!My home work was done! ....My Rad runs 65degs with no thermos running.My Intercooler runs forced air to a box that dispurses
the air over the top of Intercooler NO ICE NEEDED.JVLRacing
1303Steve - January 4th, 2006 at 10:42 PM
I bought a RS Liberty air 2 water IC for $150 from SSS in Sydney, came with a water pump and front mount radiator.
hellbugged - January 4th, 2006 at 11:19 PM
Originally
posted by Helbus
:thumb
DIY-DUB - January 4th, 2006 at 11:29 PM
Originally
posted by Helbus
No timeframe just tossing up a few ideas for more experienced opinions, the more the merrier, saves doing things twice, well hopefully, all im after
is info currently, and there will be pics etc as i go and when ive decided on final configuration? i think the word is.
Cheers FCB
DIY-DUB - January 4th, 2006 at 11:39 PM
oh yeh timeframe ive given myself 2 be 100% complete is in my "THE BUG" thread, and reasons 4 picking it also, im hoping 2 acheive it by then, if
not sooner, only thing that will limit it is availabe time and cash, both of which i will have a hell of alot more of soon.
boof2332 - January 5th, 2006 at 12:08 AM
Mine has the intercooler where you describe with thermos in a box and i duct air from under the rear window. Works a treat, although you do have to
have the thermos on all the time. Themps however are really cool. With no fans on it stays at 40 degrees, with the fans on I have ambient temps..if
its 30 outside, so is the intake temps. With the water spray, it drops it about another 10 to approx 20.
Do not forget the cold air box that will also help alot....I have recently made a scoop in the rear gaurd that feeds the rampod.
Here are a couple of pics...I think.
Matt
boof2332 - January 5th, 2006 at 12:19 AM
http://www.thesamba.com/vw/gallery/pix/211013.jpg
Here is an old pic of when it was first done...
Water to air is the best solution given the rear set up, although I want to make some 996 turbo side vents and ren that on the cooler.
JVL.....where have you been??? Is your car running yet???
No wonder you had some problems....65 water temp is far too cold..most oils do not work properly till 80.
Matt
DIY-DUB - January 5th, 2006 at 12:31 AM
thanks 4 the info/pics boof, your one of the people that im drawing inspiration from:thumb
boof2332 - January 5th, 2006 at 07:03 AM
I am trying something different today..will let you all know how it works. Reubs chopped roof will help, although there is not alot of airflow down
the rear window of a bug after about 60 kmh. This is due to the steep front window, the air turbulates high off the back of the roof. Thus the need
for thermos even in one like reubs. The new RSi Beetle has a roof spoiler that helps push air down onto the rear spoiler...or did anyone see the old
pics of the berg drag car that had the forced induction system via a large intake at the rear of the roof.
Matt
pete wood - January 5th, 2006 at 08:09 AM
That's Clyde Bergs car. It's NA but uses a sunroof shaped hole in the roof to scoop the air in. Then he has tunable airboxes on top of each carbie.
jvl054 - January 5th, 2006 at 05:15 PM
Originally
posted by boof2332
Matt
Sorry Matt disagree with temps! and oil is not the prob....The chain is rolling..JVLRacing
boof2332 - January 7th, 2006 at 06:06 PM
I know oil was not your problem..just stirring!
Although for oil to offer the correct protection/performance, they have optimal operating temps.As race engines revv hard for long periods with or
without boost(depending on event), it is logical that peak operating temps would hotter rather than cooler.
Anyway, where is your car??? Bring it to Boofs Racing Werks and you will be racing in no time. Hours of operation are...8.30pm-4.30am any night except
when I am on with the kids(alternate) 8.30-12.30am. Also open anytime the wife is out.
Matt
71superbug - January 7th, 2006 at 06:37 PM
yeah JVL i wanna see some more of your car!!!
i have only seen one or two pics and that was AGES ago.
Anthony
jvl054 - January 7th, 2006 at 08:00 PM
Originally
posted by boof2332
Matt
:PYeah nice offer!!!!I have a set deal soughted ready to go.Funds are soughted,some nice goodies as well.Work and time is holding me
back.......(It is logical that peak operating temps would hotter rather than cooler)....4hours of straight Engine Dyno time tells me my Engine is
proof in the pudding Matt.Then again after speaking to Jako Skafie Rizzo my set up is alot different to the road going subie conversions that you
blokes have done.....The darkside is looking stronger:vaderJVL
jvl054 - January 7th, 2006 at 08:40 PM
Originally
posted by Jak Rizzo
posted by 71superbug
Anthony
I don't think anyone else has ever seen this pic, JVl Racing on the track!!!
For those non believers that thought the car didn't exist!
http://images.thesamba.com/vw/gallery/pix/248503.jpg
I think I might sell this pic on E-bay:thumb
regards
Jak
:PGood on you Skaife!!! you Captilise!...making money$$$$ for your racing adventures:PJVL
boof2332 - January 8th, 2006 at 12:42 AM
I want to be a Captilise too!
jvl054 - January 8th, 2006 at 07:58 AM
Originally
posted by boof2332
A Car Yard full of EJ20Ts now that a Franchise for a Salesman!!!!(Matt):PJVL
71superbug - January 8th, 2006 at 08:29 AM
damn your car is cool jvl.
Anthony
hellbugged - January 8th, 2006 at 08:59 AM
Originally
Anthony
you should see the trailer!!:P
hi Jon. seriuosly i think its well due for a bit of a shoot on AVD, i've got a camera, what you up to in the next couple of days?
Damien
hellbugged - January 8th, 2006 at 09:21 AM
no no Jak, its been changed, modified, evolved since those photos!
I too have seen it running on a track!
yeah truely, I have, honestly, no kidding
[ Edited on 8-1-06 by dumone ]
jvl054 - January 8th, 2006 at 09:56 AM
Originally
posted by Jak Rizzo
Yes , it's been changed, evolved etc, it got painted orange, new ecu.
As good as it looks standing still I want to see it in group 1 with the GT3's at the Porsche club track days!:thumb
not looking flash on the back of a trailer.
regards
Jak
PS running around valla does not qualify as being on a race track.
Give me a break!!!Iam inbarrass that the f###in thing is not going.AGREE Jako Skaife Rizzo ...group 1 with GT3s but at the moment
this deal i have will have me running there thats my aim.On the back of a trailer is about how fast its going:o......Get the subject back on about
intercoolers!JVL
