What have people done when transplanting a turbo engine into a bug about the intercooler. I am planning to transplant an engine into my beetle that as
far as I know has never been attempted before (will remain a secret so hopefully nobody steals my idea :P lol) but the air to air intercooler in its
stock location will probably not be effective in the back of a beetle.
Would water to air intercooling (with its radiator in the front of the normal radiator) or water injection be the only effective options to cool down
inlet temps or is there an effective place I can run an air to air without having the inlet piping miles long?
just scoop the air in through side scoops seems to work quite well, i have this fitted to my car. Just depends on how much you want to cut up the body.
I have a RS Liberty water 2 air unit for my STI conversion, Im still thinking if thats the best way to go. Im going to run a whale tail the same as
the one below, so that I can get some cool air into the air intake. I also want to run air con, so I need somewhere for the condensor to fit, its easy
to run out of room with bug.
So I have 3 optiions,
1. air 2 water with its radiator in the front with the air con condensor in the tail.
2. air 2 water with its radiator in the in the tail with the air con condensor in the front.
3. air 2 air in the tail with the air con condensor in the front.
I had a thought of using decklid stand-offs and positioning an air 2 air intercooler across the top of the engine bay. Would water getting into the engine bay be an issue if I drove it in the rain?
Sounds like the water to air arrangement is the go. Dont really wanna modify the body so I can keep the sleeper look. I need to have another look at the subaru water to air setup though, there should be enough space for it under the decklid since I'm deserting the flat four arrangement.
If i told u, i'd have to kill you
My air to air in the back works awesome. I would find it hard to better it! Just drove to servo, shops, servo( no one worth racing)and home. Was
playing with the boost setting trying to fine adjust it..so was pulling max psi alot and inake temps were between 10 and 13 degrees.
Matt
a couple of my rear aluminium wing housing a pwr intercooler and twin 12" thermos...
Hey Reub.....Crazy stuff...well done! Another legal vwrx registered.
Nice work
Matt
