EJ20 n/a to ej20T same block & pistions ?
gull - May 5th, 2006 at 12:19 PM
Has any one striped a ej20 quad cam n/a down to see if it has the same internals as the ej20T ?
same motor one has turbo one has not
possable to turbo the n/a by fitting a rs inlet ect on ?
:beer
pete wood - May 5th, 2006 at 05:05 PM
The compression would have to be different. The RS motor 8.5:1 from memory VS the NA motor 10:1. I think the turbo motor also has oil sprayers pointing on to the back of the pistons but you'd have to confirm that.
GTMac - May 5th, 2006 at 08:46 PM
Different cams, different injectors and as Pete said, compression ratio different.
Doug Sweetman - May 6th, 2006 at 02:03 PM
yep, oil squirters on the turbo models arent present on the NA
