yeah i bought the manx chassis and 6a12gtt i dont know and cant find any info on this donk dont know weather to put it in the manx or a bus cos it
really feels like it weighs a ton i rekon it'll respond well to haltech and maybe custom-spec garrett ta51 id really appreciate any info on this
motor or pointers to where i can get some anyone seen one in a vw b4??
[ Edited on 8-6-2006 by dubbill ]
Name: 6A12G twin turbo
Type: 1998cc EFI DOHC 24-valve V6 with twin turbos
Power: 160kW @ 6000 (179kW 1993 Galant VR4 4WD)
Torque: 309Nm @ 3500
Sources: 1993 Eterna XX-4 FWD (fits Australian Galant V6)
engine from....
7th Generation Galant
Specs – E84A Galant VR-4 sedan
Year of manufacture: 1992-1996
Engine code: 6A12
Engine type: 1998cc quad cam 24 valve twin turbo V6
Turbo arrangement: Parallel/simultaneous
Max power: 179kw (240hp) @ 6000rpm
Max torque: 309Nm (31.5kgm) @ 3500rpm
Standard boost: 8psi
Compression ratio: 8.5:1
Bore and stroke (mm): 78.4 x 69.0
Transmissions: 5spd manual, 4spd auto
Dimensions(mm): 4620(l) x 1730(w) x 1410(h)
Weight: 1450kg manual, 1480kg auto
Wheels: 4x114.3 stud, 195/60 R15
Brakes: Ventilated disc, ABS
Gear ratios (man): 1st-2.750, 2nd-1.684, 3rd-1.160, 4th-0.862, 5th-0.617, reverse-3.166, final drive-5.443
Gear ratios (auto): 1st-2.551, 2nd-1.488, 3rd-1.000, 4th-0.685, reverse-2.176, final drive-4.422
Specs - E74A Galant GT Sport
Year of manufacture: 1994-1996
Engine code: 6A12
Dimensions(mm): 4705(l) x 1730(w) x 1460(h)
So, it's like a twin turbo version of the FTO motor. I looked at it initially, but went away from it because of the cast iron block which makes it
weigh a ton. A guy contacted me ages ago and said he was putting one in a manx, and I said it would be way too heavy and would handle like a pig. In a
bus it would be ok.
If you have bought the car I am thinking of, it was in a pretty sad state and what was left of the engine looks like it had been sitting for ages.
thanks wes but i was actually after the motors specific weight and tuner mods but yeah its prob the same vehicle yellow manx 4wslotted discs+ spare
strenghtend chassis+ 7 point cage+ 6a12g +adaptor plate + 091 box it was from north bris its is bit rough but at 4k thats less than half what my
mower cost me and should be more fun:Pill most prob shove a rotor in the manx ported for torque at low revs ie 2000 to 6000 behind my 091 locker on
the new chassis but i bought cor's old grey manx they were restoring the same day and ill have the boys do this one first once they get here:thumb
[ Edited on 1-6-2006 by dubbill ]
wooohooo go the rota...i still want a rota in a bug..but i have chosen to go ej20t instead.
so i guess after the bug i might have to purchase an rx3 coupe
Anthony
i have a gen rx3 coupe 4 sale full custom street drag awsome car spent 70k plus in last 6 yrs asking 47k for it best in oz poss best in world i also have an awsome r100 4 sale at 27k if your genuinly looking
any help regarding the 6a12gtt mitsubishi ie tuner mods etc appreciated
