Got my Kennedy Stage II clutch yesterday.
Other than a small amount of locktite should the 8 bolts used to bolt the flywheel on have washers?
I have the Volksconversion kit and it did not come with washers. I'm thinking high tensile thin flat washers should be used.
Brendan
Stock EJ has no washers. But the bolt has a slight built in flange on the head of it.
Thanks Peter, I'll check my bolts out tonight for suitability.
Brendan
didnt use any washers on my kennedy mate, loc tite and torque it in
how much force needs to be applied on the bolts when torquing them?
Cannot remember..just make sure its exactky the same...work loose otherwise.
Matt
ill find out 4 ya dude,
i gota take all my clutch and flywheel off to get it back to the block, gettin it bored next week,
will post when i find out eh,
im guessing that the torque settings for clutch and flywheel components between manufacturers would be roughly the same tho... mine isnt a jap engine
eh, but it should be something to go off
kevo,
Flywheel 72 Nm
Clutch 16 Nm
