Skip to content
Aussieveedubbers
Fitting turbo coolers on Subaru motors
Share Share on Facebook Share on X Share on Reddit
seagull Compulsive Aussie Vee Dubber
4,979 posts · joined Dec 2003 ·
#496346
I plan to fit a water to air ( stock RS liberty / legacy ) cooler to my ride .
what have you guys fitted ?
71EJVan Officially Full-On Dubber
352 posts · joined Aug 2005 ·
#496362
Exactly that. WAIC+Radiator+Pump=$200 from SSS. Make sure you get the turbo to WAIC pipe as well as the A2A one is a little different.
Brendan
A VW for everyone!!
1972 1302 German Look
1971 Bay Panel with Subaru EJ20T
1970 Type 3 squareback in progress
1971 Type 3 notchback in progress
boof2332 Custom Title Time!
1,210 posts · joined May 2004 ·
#496756
Try and get the stock pump as it increases flow when on boost.
My air to air on the trip to nelson bay did not get above 10 degrees....it has gone into negatives early on a damp morning. I have the fans off always and no water spray hooked up at present. Must be my special intales and sealed box. Maybe its the easy spooling turbo and the fact that there is alot less heat generated as the car is light and 2wd.
Matt
