Hi guys & girls.
I wonder if anyone could give me some guidance please:
My Scooby alternator has 3 thick wires (white), these are joined together (from the factory). There's also the thin Alt Light sender wire.
One of the thick wires must be the excitation coil and the other two 12V power outs.
Do you just connect the thick wires directly to the battery or should they be switched through an "Ingition On" relay?
Sorry if this sounds like a stoopid question, I just don't know
Many thanks.
Normally they have a sticker next to the plug on the alternator. Hitachi, Nippon etc...normally.......
IG is ignition supply (it is important not wire this up the permenant 12v + as it will drain a small amount of currentn trough the regulator and
rotor)
S is permenant 12v + supply This wire actually lets the regulator know how much drain is on the engine, closed loop principal
L is light...pretty obvious
and the main battery post should have heavy guage wire connected to the battery or starter motor depending on how it is wired.
These are a higher output than any VW alternator, so if you are running extra load you should run a bigger wires from the alternator to the battery
than standard vw
It's looking like it could have been wired direct to the battery via a 1.5mm Fuseable Link.
Can anyone confirm/deny this please? I can't be the only one with an alternator like this, can I?
Sounds like an EJ22.
go here
http://www.finleyweb.net/default.asp?id=142
get the ej22 service manual part 2 and have a look at page 117 of 162 of the PDF file.
Slightly off the subject, in stock Subaru’s some have 3 small connections at the alternator for the voltage regulator. Cars with this type of
alternator have the charge rate governed by the ECU and it is very common for them to show 12 volts or just battery voltage when the car is running,
when a load is applied the charge voltage will increase to around 13 – 14 volts. This condition can often be mistaken for a faulty charging
system.
Any idea which models this applies to or any further information available please.
Its the later models, they are identified by the 3 wires instead of the 2 on most other Subarus.
