Am setting up my fuel system for the EJ22 buggy, and was wondering, is it better to have the high pressure pump at the back of the car, or at the
front??
Mat
[ Edited on 26-9-2006 by mattie182 ]
I put mine at the front as they (high pressure pumps) dont like to suck for fuel....having said that , others have them at the rear and a low pressure
pump installed to feed a surge tank so it will depend on how you set up your tank and pipework and your preference for the position of the pump.Where
mine is at the front i have easy access and is close to the tank.
You
will also need to run high pressure lines through the tunnel if the pump is at the front whereas only low pressure lines if the pump is at the back (I
say lines as you need to run 2,one for the return line) I think the title should be "suck or push"
[ Edited on 26-9-06 by Mick H ]
wherever the fuel tank is..
Well, its always best for these pumps to have a head of fuel at them and blow rather than have to pull the fuel.
So best place is below and close to the fuel tank.
Or:
A LP pump at the tank feeding a surge tank and the surge tank feeding the HP pump wherever you like to put them.
L8tr
E
well,
I have the tank at the front, a low pressure pump feeding the surge tank also at the front. I would prefer to have the HP pump at the back, really
only because of space
Mat
the order should be...
main tank --> supply pump --> surge tank --> efi pump --> (efi filter) --> motor
location of the parts in the car is largely irrelevant as long as the order is correct.
BTW, make sure you flush your tanks out properly before using them or crap will clog the efi pump.
