How do people set up their exhaust with an EJ engine........(there doesnt seem to be a great deal of room between the water inlet and the exhaust
headers)
Mat
cut up the stock headers and turn them around. then weld them back together and bend up an exhaust.
Pete got any pics of yourse
i'll go take one, kinda hard to see though.
here you go.
here is the driver's side primary....
and the passenger's side primary..
they both go into a T piece, the pass side on the back and you can't really see it here, and then into an expansion joint. I'm using the factory
cat.
here is the cat and muffler. it's a bypass type design and the exhaust is very quiet which means the cops have never pulled me up.
thanks pete, do you notice any probs with the exhaust and water pipe so close, was worried about heating up the pipe, or even melting the rubber??
EJ22:thumb
[ Edited on 6-11-06 by Mick H ]
This is my exhaust, the length of the pipes are not the same from each side of the engine, this gives it more of the "wrx" note as the headers in a
wrx are much the same. I cut the original headers off and put a in a140deg 2" s/s bend + straight from the right hand side to bring it to the left
where it joined onto the left hand side. It then does a big 180degree bend and goes back to the right with the car converter and muffler.
[ Edited on 6-11-2006 by ratbug ]
thanks guys!!!!
