Hi , I am currently about to fit a holden 6cyl red motor into an off road CAMS Approved race baja buggy. The baja cage is designed to mount the holden 6. Now to the point , - the flywheel & adaptor plate are currently mounted on the engine BUT I have NO clutch & pressure plate. The clutch plate looks to have been approx 228mm , so what model & year vw approx does this suit. The pressure plate seems to have had 6 bolts judging by the flywheel to hold it on also there are 3 locating dowel pins sticking out of the fylwheel to locate the pressure plate , so what model & year approx is this out off. Diagonal pressure plate holes measure approx 245mm. The diameter across the flywheel is approx 280mm. it is a 12volt flywheel. Any Help Appritiated- Thanks.
Is this possibly an 1800 or 2lt cluth & pressure plate I need ? what diameters are they ???
2 litre Kombis used a 228 mm clutch, they arnt very heavy/strong so you may need to buy an upgraded one.
look here, there is some related info
http://forums.aussieveedubbers.com/viewtopic.php?tid=56236
Can anyone post a picture of a 2 litre kombi flywheel & Pressure Plate for me PLEASE !!!! so as to know what im looking for !
go here, get a good one........mine just arrived, 7 day delivery
http://www.kennedyeng.com/vwpo_dis.htm
