clutch fitting problem
jonnyb - June 30th, 2007 at 04:52 PM
the throwout bearing tube in a kombi gear box-can it be not used as it is hitting the pressure plate on fitting the motor.
pressure plate is a kennedy stage 4 thing which worked well in
the wagon.-motor is rotary if that helps.appreciate any help.
john
The Bigfella - October 1st, 2007 at 03:41 PM
Bump ...
I've got the same problem. I'm finishing off an old project I got diverted from 10 years back.
SSP Box with Quaife diff. KEP 2300lb pressure plate. Pressure plate hits the tube. I started cutting the tube back (I've got a spare) - but gave up and just have the standard pressure plate and clutch in while I get it running and painted, etc. The inner dimension of the KEP pressure plate seems to be the problem - its smaller than standard.
What's the go?
gazman - October 1st, 2007 at 04:03 PM
I think you may have the wrong pressure plate, ive had this problem when I changed motors once. I think earlier models had a different thrust bearing setup.
Any vw clutch experts wanna weigh-in here?
jonnyb - October 1st, 2007 at 08:56 PM
dave butler helped me out with photos and advice in his reply on the 30/6/07 check it and see if it helps you
The Bigfella - October 2nd, 2007 at 08:44 AM
Thanks Jonnyb - I found Dave's post. Mine looks a bit different, but I'll give it a go. I'll start a separate thread with pics if I strike trouble.
