Hey guys
any one on here want to make me a shortened sump? I have a spare one, I want it as short as possible, I can pay for all transport, materials and
labour. do I have any takers?
thanks
These guys do them 80mm shorter. Give them a call.
Custom Offroad
28 Hayward St
STAFFORD
QLD 4053
Tel (07) 3356 4356
Boof2332 is currently making me one. It's about 45mm shorter than stock. U2U him for a contact detail. If you can't get on to him, I'll give it to you.
i was thinking about this the other day and what are peoples thoughts on using an oil cooler, like on auto trannies, sort of acting like a remote
sump. have a on way check valve on it for when the engine is stopped. If you did that you could, in theory make the sump a lot smaller, just some
random thoughts
andy
In theory, adding total oil capacity to any engine will allow you to extend factory service intervals (reducing capacity does the opposite too) but
reducing sump capacity can lead to dramas with oil starvation etc. Adding oil coolers etc adds complexity
Slice off only what you need and try to add it back at the sump, with sump 'ears' etc
boof shortened mine by 40mm and I think it may even have a bigger capacity than standard. I'll try and take some pics to show you. But what VWcool said is correct, you need the same or greater capacity of hot oil available to the engine otherwise it will wear the oil and the motor out faster.
