The ECU reads: 8C
22611 AB393
A18-000 DB3 5908
It's a 4- pin ECU and I think it's from a '95 automatic JDM Ej20TT
Thanks.
Have a look through my diagrams and links here -
http://www.osp.metrohosting.info/wiringgallery.html
and see if you can find it. Or post a pic here of your ECU's pinout and plugs and I'll have a look for ya ![]()
Link doesn't seem to be working but I took some pics for you that hopefully are of any help.
Really need to see the ecu unplugged to count the pins. Does it look like this?-
Strange that the link didn't work, it does for me. Try http://www.osp.metrohosting.info/index.htm and click on wiring etc.
Just checked and mine is "13" "8" "6" and "11" instead of the "11" "6" "8" "13" you wrote.
Link still doesn't work for me.
Sorry that pic is of the plugs, not the ecu. If its a mirror image then it is the correct one.
Try these pics:
preMY97-1
preMY97-2
preMY97-3
preMY97-4
I hope these links work for you! If not I'll upload them directly to this thread.
Just double check each feed as it doesn't specify if these pics suit the twin turbo or not.
