Sitting in my 67 Fasty is carby EA82 with the Sherman adapter plate etc and a SSP box. What else Suby would have the same bolt up pattern, preferably injected with more grunt?
EA81/EA82 are different to the EJ motors, so the only injected motor you could use would be an EA82 if you can find a FI one.
EA82 Turbo, 1781cc EFI OHC, 89.5kW @ 5200,Torque: 178Nm @ 2400, from Vortex.
As has already been said, EA81/82 are different to EJ. I have a adapter plate and flywheel sitting here that i cant use on my EJ18.
ea81 and ea82 are different bolt up to gearbox patterns.My adapters are different on each.
