boxer 6 cylinder subi motor from 2000-2002 maybe also called an H6
has anyone any experience with such a beast into a VW?
Nick
Humpty has the SVX motor for sale c/w the adapter plate wiring ( every thing ) drop him a pm
The EZ30 is good , but makes in power up in the rev range you will find this a big pain . I had a H6 ( outback )
There are two that I know of in the US and from what I hear, they are both using aftermarket ECU's I think... Very smooth HiTec engine, low on bottom
end grunt and can be very sensitive to conversions from what I have read...
Then of course you have the EG33 option...
Interesting - thanks. I really want low down power as it is for a kombi not a drag beetle. Ideal I guess max about 3,500 rpm or lower...
I found details quoting EZ30 as 162 kW @ 6,000 rpm and torque of 289Nm @ 4,400 rpm so I see what you mean.
Lot of motor for the $ though.
Any comments on what is going to be the best option for a bus with 6 passengers (or more!)?
V6 ecotec...haha mainly cos i'm trying to get rid of one...be a great engine tho![]()
EG33 has loads of bottom end grunt...
