I was at the wreckers this afternoon and spotted a written off liberty.
I popped the hood to find the complete engine, not even the battery had been taken.
I need to check out what size it is and what and where everything i would need for a conversion is in the car.
Speedy responses would be appreciated because i think bits will be missing very sooon.
all libs were 2.2 till about 96 then from 96 to 99 they were either 2.2 or the pov model had 2.0L
its stamped on the engine block just beneath the alternator
did you notice what year it is?
I tried but preety much all the writting was in chinese or sumthin.
But ill probably go check it out again tomoro so ill let you know.
The only other thing is is there anything important in the corner where the battery is, it was the only spot that had real damage.
just check the the timing belt area hasnt been damaged
ej22 are non-interference motors but if the cam gears been hit the belt may have jumped a tooth or 2
but nothing terribly important
just the fuse box which isnt needed
Okay
Ill write a list of stuff that you have listed on your other thread and let you know how it all goes.
i'd be surprised if it was
i know on mine pretty much only the australian compliance plate was in english
the one with paint, trim etc had a lot japanese scribble on it
There was one plate that was english but it was all scratched up and was on the drivers side and the jap one was on the passenger but ill get pics up today at some point
I could be wrong, but there should be a year stamped inside the oil filler cap. Nothing to say it hasn't been changed with another engine, but it might be correct.
Here is the engine,
Here is a pic of the VIN plate.
I need info on engine size, because i saw a website that said its a EJ25 but i saw EJ22 stamped on the block.
Also the guy wants 650 for it, how should i check see if it runs.
is $650 the whole car or just the engine?
its a 22 by the way
if theres no damage to the timing belt covers and nothing touching the fan belts putting the donkey dick back on the throttle body and airflow meter
it should run if nothings damaged in the fuse box
The way I would see it.
The motor would have to have been running for the car to be driving to be smashed!
If it has done under 200,000km, then maybe it will be good for another 100K, depends on it's service history
If it has only done low 100K then it should be a good one.
You would be very wise to fit new cam belt kit and new water pump no matter what when you put it in your car. They are good insurance.
You need the engine complete with flywheel air flow meter, wiring loom with relays igniter computer, engine mounts, exhaust just past catalytic
converter including O2 sensor and wiring, carbon canister.
No harm in grabbing all hoses at the other end, not at the engine end, if you get to take it out yourself. Grab the fuel line clamps on the high
pressure fuel lines etc.
I got all the above removed from vehicle and delivered from a 112K km vehicle for $1100 a few years ago, so $650 is real good.
650 for the whole car.
Couldnt check kms cause didint have key but fuse box is ay okay. Timing belt covers i dont know about, i could turn the thing at end of arrow.
What do i do bout the key. If i could get the ignition switch out of the barrel and use a screwdriver is there anything stopping me starting it.
Ive got one exam in the morning then i should be able spend an hour trying to get it to kick. I plan on taking oil, coolant, water and bit of petrol.
Is there anything else i need to take.
The whole car i spreety smashed, here is a pic.
thats only the A/C compressor clutch so it will spin on its own
you wont need the key to check KMs they didnt go digital odometers till late 90s
how the passenger side for damage? cos to fold in the middle like that has takes a fair impact, it may spent some time on its side
$650 is ok from a wreckers for teh whole car if it runs ok
it takes a good day to pull the looms out of them so its worth getting the whole car if poss rather than them cutting the shit out of the loom
left side seems okay cause mirror etc is still all intact.
I would be bringing the car to mine so ill be removing it all.
where bouts is the odometer cause had a look but couldnt really see.
But will i be able to start with just the ignition switch
I have cam covers here if you need them + other bits & bobs
Is the car maual ? duel range ?
looks clean from Perth
3 hours to get the motor & loom out , just cut the front off with a 9" & lower it out the bottom
its just in the middle of the speedo
it would have the same dash as mine they never changed it in that series
Yeah i had a look couldnt see it but, will check on way to school tomoro.
And its an auto.
Do you think i could see the doors and interior bit to get some money or what
you can try but its not really worth the hassle cos you get bugger all for them and lots of people wasting your time
pretty much all mine went to the crushers, the headlights and back bumper sold gearbox is still there
if its AWD then the gearbox will sell easy but FWD cant even give them away
Okay cool ill check that tomoro.
Will have a look for logbooks and stuff too.
What does noise am i looking out for if i get it started, like lifter rattle etc
The last FWD auto I had sold for $280.00 as it was needed for the out put shafts ( stubs out the auto )
Front drive shafts $130.00 ( larger than wrx units )
Electric door switches $200.00
Tail gate $180.00
carpet fits sedan or wagon $100.00 ( mine was clean )
$100.00 scrap for the shell
$78.68 loose change in the car
The tailgatei think is stuffed but yeah will check
Would that be much different in NSW
Didnt get to the wreckers today but will tomoro.
I plan on making a list of all sellable items on the car and then checkin on the net.
. No
idea what they were & went in the bin that's a classic Neil.
I bought a 73 superbug for $50 to get the IRS gearbox, arms, cv's, etc to do my IRS conversion on my Baja. It came with free rats living under the
back seat, and an awesome quality pair of blue plyers which I still use regularly! Not as much fun as $78 and some drugs
Update,
Its done 17100 kms, battery was dead today but got jumperleads for tomoro.
Tailgate is salvage able, its got non electric winows and the dash is stuffed cause of glass rubbing on it.
How much do Subi brakes sell for?
And how do i tell if its AWD
your looking for a tail shaft that comes out of rear of the trans and goes to the rear diff
stock brakes dont sell
If this has been on it roof , you would be best to remove the spark plugs and crank it over with out them. Water / oil / fuel is not able to be
compressed and if there is any chance of these in the cyl when you start it there is a chance it will throw a conrod.
I think this is a FWD auto , as there is no fuse on the driver side strut for FWD mode over ride.
