Hi, I'm researching over the next couple of months to convert my '70 fastback to Ej20T power. I have most of the process down.
There is quite a bit of info around - with subynotch.com etc and of course on this forum.
I haven't had the engine out of my ride before - so not too sure about the crucial piece of info - how the block will fit in. I understand that you
have to flip the water intake, relocate the alternator, remote oil filter, move intercooler and possibly plug oil cooler.
My question is does anyone have information on mounting the block. I have a IRS setup - and will be using a Rancho street pro box, but does anyone
have a good custom mount setup? I'm hoping that something could be fabricated to bolt up to the original hanging mounts? The more info the merrier
please..
http://aussieveedubbers.com/viewtopic.php?tid=84426
Ok.. but I'm not interested in purchasing a made conversion.
Ah yes, I took that initiative also.
search for hellVWrx
Loads of pics for mounting sub frame off vw points on body
Actually I do agree.. I was emailing Rjes and that was his opinion.. but I think he had in mind that people want to keep their boot space.. ahhh.
nope.
Do you think you could email me at stafdawg@gmail.com with some pics of your mounting setup - it looks nice and simple. Cheers.
sent a reply to your email , my fit uses no factory mounts as i wanted nothing to fall apart as its all 10 and 6mm plate drilled and tapped with custom cradle setup to use subi engine mounts. the only mod to intercooler was to lay it down a little more so to lie level with the top of the alt. As i said buy mine cheap as and just needs a tidy up .
I have attached the only other pics that I have of Simons brothers notch that he sent me many years ago.
Mine is in a beetle, so that won't really help u.
regards
Jak
Mark has had that subaru Rs turbo motor in there for years. I think that is was one of the first ever conversions done down under
this machine is very cheap to run and is a true sleeper, see at the drags come summer Chopper !
that's very low. how often does he scrape it on stuff?
I can not say I seen many scraps on the under side there Pete. I have a look next time Mark comes over
So that frame on the red fastie looks to be quite simple, with tubular steel parts welded up. Would it be best to go that route - or something fabricated by a professional shop? I would be getting a engineer cert in VIc for it... so may have answered my own question there. RJES makes a nice looking mount for the VAN conversions.. I wonder if something like that can be designed for the Type 3.
found some side shots of mine and inner reinforcement
and another
Well - I was just cruising on trademe.co.nz in NZ and came across a EJ20T with 89kms with a kennedy adaptor attached for about $700aus. I bought it
straight away as even with shipping it works out a pretty good deal. So I guess this will now become a build thread in the coming months.
A few questions for the pros out there. With the cooling system is it best to fabricate a filler tank directly on the engine to alleviate the gravity
feed problem?
My fastie is already fuel injected - I want to buy a new pump for it to handle the turbo - but can I still use the same return system from factory? I
would replace all the hosing of course.
Keeping an eye out for this
Why did you swap forums
Great build - and yes you have answered many questions on my mind. Can't wait to get started.. but then I haven't got anything to start with for a
while - just be collecting parts I reckon.
Staf
Crated and being sent over. Looks like the loom has already been trimmed to the right places hopefully. This engine was ready to go into a VW with
adaptor fitted, but then the guy got relocated.. pretty happy how that worked out
What would you say the best radiator choice would be for this conversion. I would like to buy something that has fans and fan shrouds already attached.
stock subaru rad is good if you can find a complete one.
heck if you use the stock ECU you can use it to turn the fans on too.
Cool - I was wondering why people don't use the scooby radiator - surely it can't be hard to find one. Yeah I will use stock ECU. So do they measure up to a good fit?
Its mainly cos they're so big, being crossflow with deep tanks the end up too wide to fit a beetle well
dunno how much better a type3 would be
plus you dont need to go that big if you use metal lines underneath
I'll have to do some measuring. Looks like another common one to use is the hyundai coupe.
Would using metal water pipes dissipate heat quicker than using plastic? Anyone got thoughts about plastic plumbing.. it seems to be a good choice
for flexibility and fitment.
Next on my list of stuff to do is big brakes. I have a set of ATS cookie cutters that are ready to go on.. I'm going to keep the rear drums on and
run adapters for the studs, and just focus on the fronts being a new setup with pattern drilled. I like the look of the corvette calipers that a
member here makes - but can't seem to get in touch with him?
http://forums.aussieveedubbers.com/viewtopic.php?tid=36884&page=9
What else is available here? I know of the 944 option - and being 944 I'm guessing Audi 100 has the same brakes too. Someone in the link I posted
was also talking about adapting BMW 320i calipers to type 3 brakes.
