Hey guys, looking at changing the diff ratio in an 89 T3 van,
currently running 4.83:1
Would a 3.9 be too high?
probably.
you want the 4:56 that was in the 091/2 litre box.
Not if you have enough HP to push it.
just stick some bigger diameter tyres on the back
bigger tyres could work well, currently running std 185/14's
1st 12kmh (or slip start in 2nd)
2nd 25kmh
Would anyone have any larger wheels/tyres that I could borrow/try.
15"-16" 89T3.
Thanks,Dave.
Hi Dave, I'm in labrador you are welcome to try some of my 16's...40k in 1st 70 in 2nd only trouble is most non standard rims require longer studs...cheers Rob
Thanks Rob, what size tyres are you running on what type of wheel.
Cheers, Dave.
Hi Dave i currently have my country mouse tyres on...i went camping last weekend but for extended road use i run my city mouse tyres...both work out
the same diameter...gives 105km/hr at 3000rpm
[img] [/img]
[/img]
[img] [/img]
[/img]
    dirt tyres are 245/70/16  road tyres 255/65/16
   perfect for a kombi with sooby motivation
the steelies are BA falcon 16x6.5 and the mags mercedes 16x7.5...both have ET around 36
