Pros and Cons of Various parts!
Bootman - March 8th, 2004 at 06:07 PM
G'day,
I'm new to the forum and VW's. I was into Minis for a long time and would like to ask about sunroofs, tyres etc.
What does adding a sunroof do to the structual integrity of a Baja Bug?
If using large tyres on the rear, what is the maximum size that would be recommended? This vehicle will be used for Road and off-road driving.
Are there any recomendation as far as ride height adjustments?
What are the benefits of Coil Over springs?
daz67 - March 10th, 2004 at 08:24 AM
Added a Sunroof to my Manx and no problems!!
Baja Wes - March 10th, 2004 at 09:37 AM
Originally
posted by Bootman
G'day,
probably not alot.
most people run 31x10R15's on the rear
Are there any
yes, it should be adjusted.
What are the
they are cheaper to fit than adjusters.
[Edited on 9-3-2004 by Baja Wes]
56astro - March 10th, 2004 at 09:49 AM
VWs have several beetle gear boxes, and several kombi gearboxes, each having different ratios.
Do you know which gearbox you have?
