baja bus rear flairs?? ive noticed alot have them. wat are thay off most of them have a good shape that maches the line of the car . or are thay made 4 the kombi ? if thay are custom kombi were do i get some ????:thumb
Originally they were copied off a 40 series cruiser, but you can buy them from Volksconversions on the Gold Coast
hi graham finely got a bus 2 baja " ok so 40series?? do u know what the ones from the volksconversions are worth???are thay just 40 series or have thay been modiffied??
The 40 series have one leg longer than the other.......
The Volksconversion ones are the correct length for the kombi
ok cool thanks
You'll also need to modify the sliding door arm to clear the flares when you open the door. I think i lengthen mine by about 100mm, used a kombi tie rod to do it. And you need to move the stop the same distance back so the door swings into the body at the correct time.
Try volksengineering as his are made to the kombi shape,
if its for a van he may have the spacer for the door, to extend the swing so it doesn't hit the guard .
I have a picture some where, but it maybe to big
0408199639- 38417005
thanks 4 that no shore which way im going yet baja or not 2 baja ???????????
