What kind of options do I have in regards to offroad/mud tyres to fit on 14" rims?
get 15 inch rims. u wont find anything for 14s
I feared as much. Not having much luck finding any 15"s either. Keep looking I guess.
make some man.
find some old 7 ot 8 inch cruiser white spokers whose rim will match the centres you got then cut and clean so both will match. then bolt centres on
hub and slide rim over to get off set then tack, drop buggy and check through susp travel, then jack up again and finish welding taking note of
balance by spinning wheel between welds. then drive. trusting it with your life (just like the weld that holds the rear of the pan to the front of the
pan. haha)
(dicklaimer, for off road buggies only. not for road buggies. use professionally made wheels like from custom off road or Mr Psychobugger for road
use.) haha
Yokohama and Bridgestone make a 8.5x 14 tyre
helter if he has 14 inch centers then u couldnt weld them into 15 inch rims.
surely u could find a set of wide stock wheels pretty easy. they are always up for sale.
if not then u could still use helters approach and get some stock 4.5 inch bug rims and buy some blank 8 inch or whatever u want rims.
and go to a place that can reset offset in wheels and get them to change the centers.
i have 8.5 inch roh rims with 15 inch stock beetle centers in them on the rear of my car.
or u could buy some peco stars or similar from custom offroad.
Also there's a much better range of off road style tyres available in 15" due to it being a more common 4WD size, which would probably, in the long
run, save you money over the option of trying to source out a harder to find 14" tyre...
Good luck...
I don't have any good pictures of the tyres at the moment but you can see the tread in this photo.
try searching on the tyre manufacturers websites. you would be surprised howmany people make them (mainly for small jap 4wd's I guess)
