just for authenticity sake how do i tell a real manx from a clone
Go to manxclub.com and manxclub.org and follow the prompts.
Generally speaking
Feel the thickness of the fibreglass in several places. It is about 5mm thick on a genuine Manx and quite thin on a clone. If the mudguards flex
easily the fibreglass is thin and it's a clone/copy
Look for a Meyers Manx ID plate , in the middlle, either above the gearshift link hole behind the chassis number or on the fire wall above the pedals.
A set of holes about 2 inches by 1 1/2 inches may indicate a missing plate.
Look for tubes running the full length of the sides under the curve beneath the sides. They should be about 1 1/2 inch in diameter. Sometimes it is a
piece of vacuum cleaner hose, or a U shaped piece of cardboard.
Manxes have a wheel hole with a little dimple in it and a battery hole under the rear seat area. Manx 2s do not have them.
There should be a small bump for a badge in the front of the bonnet, which should be plain, without other bumps, ridges, scoops etc..
In a very old Manx the dash board is separate, fits on a steel frame and is made of plastic. Later models have the dash as part of the bonnet.
There is a cut out on a small raised area directly above the engine.
That's all I can think of now.
Happy hunting. Remember that there are in existence many more copies of Manxes that there are genuine ones, so if you find a genuine one you are very
lucky.
