link pin bump stops
aussiebaja - August 20th, 2006 at 06:18 PM
hi guys ,was just looking at my link pin front end ,if i put in adjusters what will i have to do with the bump stops ,just cut them off or what
subibaja - August 21st, 2006 at 10:48 PM
yes
but usually relocate them above the top arm
custom off road can help there
pete wood - August 21st, 2006 at 11:37 PM
you'll also need to clearance the frame head for the steering arms. full drop means they hit on the top of the tunnel otherwise.
Terry, have you got a pic of the COR bumpstop mod? I need to do mine at some stage and brissie is a bit too far away.
aussiebaja - August 22nd, 2006 at 06:07 PM
sorry guys i need to lift it ,its a baja
