Oil Cooler location ?
liam66 - October 11th, 2007 at 09:45 PM
I'm fitting an external oil cooler to my J&S beach buggy.
Motor is a stockish 1600. Only mild offroading planned.The rear doesn't lend itself to fitting a cooler and getting reasonable airflow through it.
I'm trying to avoid relying on a electric fan to get airflow, or putting the cooler where it get hammered/ packed with mud.
So the question is- If I fit the cooler at the front of the buggy will the standard oil pump cope?
Craig Torrens - October 11th, 2007 at 09:46 PM
if its a stockish 1600 you don't need an external cooler.
[ Edited on 11-10-07 by Craig Torrens ]
liam66 - October 11th, 2007 at 10:08 PM
The motor I have didn't have an internal one (long story) not going t pull the engine out to fit one, so this seems like a passable solution. (really dont want to pull the engine back out)
aussiebaja - October 13th, 2007 at 06:18 PM
mate i mounted mine on top of the rear cowl ,its barely viable from inside the car ,
